How to cycle though Transform Constraint?
serhiiprihodko
serhiiprihodko
Hello, i just want to ask is there any way to bind one hotkey to toggle between Transform Constraints? I need simple  edge slide, surface and none to be switched via one key. Thank you!Screenshot_1.png
brentmc
The command you need to use is xformConstraint
  • To get the current constraint use xformConstraint -q -type
  • to set the constraint use xformConstraint -type edge (or "none" or "surface")
https://help.autodesk.com/cloudhelp/2024/ENU/Maya-Tech-Docs/Commands/xformConstraint.html
Brent McPherson
Principle Engineer
