Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
how to convert instancer to polygon or object
7 REPLIES 7
Message 1 of 8
18481 Views, 7 Replies
I tried using options from modify. Its not working. need help
7 REPLIES 7
Message 2 of 8
ray
The command you used converts instance objects (objects duplicated as instances with the duplicate special command) into geometry, not the particle instancer.
I don't know if Maya has some tool available for baking particle instancer into geo, I see many people are using a script, like this:
http://www.sigillarium.com/blog/lang/en/726/
Message 3 of 8
mspeer
Hi!
You can't convert Particle Instances to Polygons.
But MASH can do this (Bake Instancer to objects)  and you can connect nparticles to MASH:
http://help.autodesk.com/view/MAYAUL/2017/ENU/?guid=GUID-4CAEABB4-2D1B-473B-B5BD-F2FB00AE8CB4
Message 4 of 8
mspeer
in reply to: mspeer
Hi!
I might need to add here that this MASH tool of course also works with the Particle Instancer node (it's the same Instancer node as used for MASH).
Message 5 of 8
iekomedia
in reply to: mspeer
Hello can you explain how the Mash  instancer to geo works. I have a scene or rather you can read my post from the link below. it looks like its working but nothing shows up in outliner during processing and I believe while waiting it crashed so I don't know how far it got. but considering the lack of information, would be hard to tell if its working or how it works. Thank you!
https://forums.autodesk.com/t5/maya-dynamics/trying-to-convert-a-nparticle-instancer-to-polygon-and-...
Message 6 of 8
pixelwash
in reply to: iekomedia
I didn't understand how to use MASH to "import" the nParticle instances, and convert them to geometry either, but I did find another MEL script on Highend3d which still worked with Maya 2018. https://www.highend3d.com/maya/script/instancer-baking-for-maya
(To those that don't know how to get this to work, simply open this script in Notepad, copy it, and paste it into the MEL script editor (after first clearing the editor's display completely). Then select the script in the editor, and select "Save Script to Shelf" in the editor File menu. Select your particle node, and the shelf, and I found there was no need to check anything to do a basic instance to geometry conversion. It takes a while though if you have tens of thousands of instances.
Message 7 of 8
la19c.djimenez
in reply to: pixelwash
I used it in maya 2022and still works! still takes a while but works perfectly : https://www.highend3d.com/maya/script/instancer-baking-for-maya
Message 8 of 8
andymc4997
Hey everyone,
Any way to do this with Maya '24? the High End 3D link is broken, and the InstancetoGeo python script gives me this error:
# Error: Missing parentheses in call to ‘print’. Did you mean print(…)?
I thought I found a slick way to simulate rice filling up a container, but now I'm at a roadblock :/.
