Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
How can i move my groomable splines with my mesh?
1 REPLY 1
Drywink
502 Views, 1 Reply
I finished the grooming of my character, but now i need to change his position a little bit. Everything work fine for my splines descriptions, which follow my mesh as expected, but my groomable splines description doesn't move the groom with my model, only the preview follow the mesh, but not the yellow splines used for the grooming.
Is there a way to move the model and get the groomable splines stay fixed on it?
1 REPLY 1
in reply to: Drywink
Hey,
I was having the same problem as you and worked out a fix. I know you posted this a long time ago so not sure if you're still looking for an answer. Anyway, if you change the density of the groomable splines to any other number, it will reset the splines to the location of your mesh. It's a bit of a workaround, and wont work in animation previews, but its something. Hope that helps 🙂
