[HELP] Objects Are Too Small
My settings are complete factory default. Unit = Centimetre
But when I create a poly object or a light etc. it is tiny (1cm wide or something). I can scale it to make it bigger but I don't know how I can make the default scale of the objects bigger. Should objects be created this small normally?
For the images: 1 Grid square = 25cm
J450NP13
That's normal....zoom in...if you want to look at a 1x1x1 cube.
J450NP13
Go to create and create what you want with the unit sizes you want.
pshwayka
To change the default sizes for polygon objects, click on the settings box for them and adjust the sizes there. Once you have done that, the values you entered will become the default for future use.
Thanks for the help everyone. I've set the poly objects to be created at 50 units. I've moved from Max so it's just a bit strange creating objects like this.
J450NP13
After you create a primitive you can change the size of it in the attribute editor
