Heads up display font is blurry
brunogf13
brunogf13
Hello There! Have been using Maya for a while now. Have a 3 year student version and I'm using Maya 2020.4. Just recently I noticed that my heads up display, that I use for the Polygon count, the text/font is a bit blurry. Doesn't matter what size I choose to apply. I noticed because I see other users screen (tutorials) and their font is crisp! Now, I only notice this in the Heads up display fonts. Everywhere else seems to be fine. I'm sending a screen shot attached. Any ideas of how to fix this? I'm assuming it's not the PC, otherwise All the fonts would be blurry. Including other programs, which is not the case! Hopping there is some kind of setting that can fix this..
Thanks in advance.
dariush
Are you scaling the view either in Windows or in Maya itself? Try changing your Rendering engine for viewport 2.0 mebbe?
brunogf13
Hello! Thanks for replaying! No, not scaling the view on Windows or in Maya. Using the default PC (recommended) resolution of 1920 x 1080 (in my case). Changing the viewport render has no impact on that. Again, I don't think this is a PC issue, otherwise all other Fonts would be blurry, I guess. Including in other applications. Which is not the case. I get blurry and not so crisp fonts Only on the Heads up display text.
It could've been something while loading, or maybe your graphics card is having issues. How long has it been happening?
brunogf13
Hi there! So I found the solution for this. Apparently it had to do with my Nvidea graphics card settings. I have restored it to default settings and now all the fonts are clear Crisp! So I would like to close this Post, but not sure how to do it. Couldn't find that in the options. If anyone knows, please let me know. Or if anyone from Autodesk sees this post, please go ahead and close it. Thank you.
dariush
Just Mark your own post as the solution, if u can or just leave it as is. Glad it worked.
