Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Freeze transformation trouble......!!
3 REPLIES 3
novel3d
616 Views, 3 Replies
1. make Cube. (scale 1.1.1)
2. tranlate X : 10000000, moved
3. Modify > Freeze Transformation.
>>>>> Cube Mesh Error
The cube's mesh breaks as proceed. I do not know why this problem occurs.
## The unit I use in Maya is centimeters.
## maya 2018 student version.
plz....!!
3 REPLIES 3
mspeer
in reply to: novel3d
Hi!
Don't move an object that far away from scene origin or you will get precision errors, that's normal (for every 3d engine).
(Just move the cube only 1 000 000 units in X and then use extrude in x-direction, you see the stepping?
Try extrude in an other axis direction where you don't have such high translate values => no stepping)
novel3d
in reply to: mspeer
yes. extrude also works strangely T.T
is there no solutuion??? nothing?
mspeer
Hi!
No, this is a limitation of all 3D engines, including all game engines.
Computers have their limitations and cannot compute infinite precise.
That's the reason why it's very tricky to support large levels in games.
