File Path Editor not updating file paths on Dropbox
Message 1 of 1
Hi all
The File Path Editor does not appear to update the file paths from an old path (on a separate server) to one which is on Dropbox.
If we run the File Path Editor and point to the current sourceImages folder, the file path remains as the old path.
However, if we then click the ‘Reload’ button in the Attribute Editor the texture updates and the path updates to the new, correct location.
The Color Space can change using this method and is not ideal for a scene with hundreds of textures.
A workaround seems to be to create a new sourceImages folder (i.e on the top level of Dropbox), repath to this folder and then to repath again to the new sourceImages folder.
Could this be a Dropbox issue?
Cheers
Steve
Replies (0)
