If you are able to import your file into FBX Review, I will assume you can also import it into Maya as well. This would mean that the FBX file itself is ok.
We think the problem is on the Unity importer side. We can't test other packages (i.e. Unity, Unreal) because we have no control over their developement. It is up to the individual apps to update their software.
The game exporter is tested in a way that we make sure that FBX files are exported correctly. If they can be imported back into Autodesk products (i.e. Maya, FBX Review, Stingray), then we consider it working.
The good news is that you can revert back to SP1 quite easily. Go into Control Panel, and go into Uninstall a Program, on the left hand column, choose View Installed Updates. There you will see the SP2 update, if you uninstall this, you will revert back to SP1.
I suggest you start a post in the Unity forums to see when and if they will update their importer.
-Carlos
