Extend motion path without changing existing points
I  have a motion path keyed out that works great, but it's too short.   What's the best way to add more path?   Can you create a second curve and join the motion paths together or is there another way that works better?
sean.heasley
Hi @Anonymous
Do you want to extend how long the motion plays for?
If so you could simply move the key(s) down later in the animation.
Please let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Sean - I do want to extend how long the motion path is, that is correct. If I extend the length of the keys and drag the path bigger though, it will mess up the timing on the existing path.
sean.heasley
Hi @Anonymous
I might be misunderstanding your issue. When you get a chance, can you please post a video or screenshots of your issue so I can get a better idea of how to help you?
If you need a video capturing program, Screencast is a great option that we use here at Autodesk
Please let me know if anything changes!
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
