Expression Editor Error - Will Not Load! (?)
Using Maya 2016 on Mac OSX 10.11.2
My Expression Editor will not load -
// Error: file: /Applications/Autodesk/maya2016/Maya.app/Contents/scripts/others/expressionEditor.mel line 2221: Object 'EEmultiText' not found.
I have found forums suggesting to find the Maya 2016 folder and then Preference Folder and clear it but I cannot find any such folder -
I have even uninstalled and reinstalled Maya but no success -
Help!
pshwayka
You can find instructions for how to do that here.
Well I did see that solution but it wasn't working - it wasn't working because in the string /Users/<username>/Library/Preferences/Autodesk/maya/<version>/for some reason Mac decides the 'Library' folder is to be hidden - once I figured how to unhide it I was able to sovlve the problem
But thanks for replying!
Hello, sorry but how do you unhide it?
I'm glad you asked because I've long forgot and had to relearn it- and be aware I am in OS X (El Capitan 10.11.6) but should work regardless
Open MAC 'Finder' > click on your user name > you now see all folders but maybe the 'Library" is not there so (with three button mouse) > Right click in blank area under all the 'User Name' folders and an 'Option Menu' will pop open > Then choose 'Show View Option' > Another menu window opens and at the bottom you should see 'Show Library Folder' > Click the little box next to 'Show Library Folder' > You should see "library" folder appear in your 'User' menu
I hope this works for you and you can sigh in relief
Thank you so so much 🙂
*sigh*
I went in to try and fix the Expression Editor... but it did not work...
Is there any other work around???
https://www.youtube.com/watch?v=ocpQd0_e6I0
