exporting ShaderFX shader to Unity3D?
Is it possible to export a shader created in ShaderFX in the Unity game engine?
sean.heasley
Hi @Anonymous
No Unity doesn't support Maya ShaderFX. The only shader that easily translates over to Unity is phong/lambert or the stingray PBS shaders.
mspeer
Hi!
2 links that may help:
Export ShaderFX materials to HLSL, CgFX and GLSL:
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Maya-Lig...
Shading Language used in Unity
https://docs.unity3d.com/Manual/SL-ShadingLanguage.html
sean.heasley
Hi @Anonymous
I'm just checking in to see if you need more help with this. Did the suggestions that @mspeer and I help you at all?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
