Exporting FBX Thumbnail missing
seanbyrneW73YP
seanbyrneW73YP
With Maya 2022.2 I've lost the option to export a selected object with a thumbnail when making your own little asset library. What's happened? The was usually an option for FBX Export that is now just Fbx.
brian.kramer
I notice that in the File type menu you have selected "Fbx", however when the fbxmaya plug-in is loaded correctly the value in the option menu should be "FBX export".
Using Windows > Settings/Preferences > Plug-in Manager try unloading the fbxmaya plug-in and then reloading it. Perhaps even restarting Maya between the unload and reload.
Brian Kramer
Software Developer
brian.kramer
This is a known issue.
The current workaround is to open Windows > Settings/Preferences > Preferences. Choose Files/Projects from the list and then under File Dialog set the Dialog style: to Maya default.
Open the Plug-in Manager and unload then reload the fbxmaya plug-in.
The Export Selection option box should now display in the File type menu menu a value of "FBX export" instead of "Fbx" and the Thumbnail/Playblast options will be displayed.
Brian Kramer
Software Developer
seanbyrneW73YP
Wow this was so annoying and yet such a simple fix, thanks!
david_katz9S8G
Community Visitor
Community Visitor
Ironically the fix for me was the opposite, changing the setting back from Maya to OS Native. Thank you for showing me these settings.
robszczerba
Looks like this bug is back again in 2025.2.
i switched to Win OS file browser as external hard drives weren’t being picked up by Maya.
So an unexpected side effect is FBX Export disappears…
