Same problem here, no file saved on the chosen folder (or anywhere else) and this is what the Script Editor says:
// Result: scriptEditorPanel1Window|scriptEditorPanel1|formLayout412|formLayout414|paneLayout6|cmdScrollFieldReporter3 //
import mtoa.ui.arnoldmenu;mtoa.ui.arnoldmenu.doExportStandIn(selected=True)
ExportSelection;
checkForUnknownNodes(); projectViewer ExportActive;
proc int fbxExportSel() {int $rtn = 0; if (`exists IsExportActiveOperationMode`) { $rtn = IsExportActiveOperationMode(); }; return $rtn;}; fbxExportSel();
// Result: 1 //
// Result: 1 //
toNativePath(`workspace -q -rootDirectory`);
(u"//nonews/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/").replace("/","\\");
# Result: u'\\\\nonews\\W\\CG Works\\3D Products\\Times Square\\7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]\\Maya\\' #
// Result: \\nonews\W\CG Works\3D Products\Times Square\7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]\Maya\ //
workspace -q -rootDirectory;
// Result: //nonews/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/ //
fileOperationsOptionsUISetup ExportActive FileDialogOptionsGrpBoxLayout;
np_getPrimaryProjectFileRules 0;
// Result: Scenes scene scenes Templates templates assets Images images images Source Images sourceImages sourceimages Render Data renderData renderData Clips clips clips Sound sound sound Scripts scripts scripts Disk Cache diskCache data Movies movie movies Translator Data translatorData data Time Editor timeEditor Time Editor AutoSave autoSave autosave Scene Assembly sceneAssembly sceneAssembly //
fileOperationsOptionsUIInitValues ExportActive FileDialogOptionsGrpBoxLayout"ASS Export";
import mtoa.utils;mtoa.utils._objectStore[2104613491656]('fileOptionsScroll', 'post', '-expandProcedurals;-shadowLinks 0;-mask 6385;-lightLinks 0;-exportAllShadingGroups;-boundingBox;-fullPath', 'fo_optionsCallback')
# Result: 1 #
fileOperationsOptionsUICallback ExportActive FileDialogOptionsGrpBoxLayout "//nonews/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/Vegetation.ass";
fileCmdCallback;
fileCmdRestoreCallback;
import mtoa.utils;mtoa.utils._objectStore[2104613491656]('fileOptionsScroll', 'query', '', 'fo_optionsCallback')
fo_optionsCallback("-expandProcedurals;-shadowLinks 0;-mask 6385;-lightLinks 0;-exportAllShadingGroups;-boundingBox;-fullPath");
// Result: 1 //
# Result: 1 #
(u"//nonews/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/Vegetation.ass").replace("\\","/");
# Result: u'//nonews/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/Vegetation.ass' #
fileCmdCallback;
fileCmdCallback;
fileCmdCallback;
fileCmdCallback;
fileCmdCallback;
fileCmdCallback;
file -force -options "-expandProcedurals;-shadowLinks 0;-mask 6385;-lightLinks 0;-exportAllShadingGroups;-boundingBox;-fullPath" -typ "ASS Export" -pr -es "//nonews/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/Vegetation.ass";
fileCmdCallback;
HfSaveSceneCallback true 1;
workspace -q -rd;
about -application;
// Result: maya //
about -product;
// Result: Maya 2018 //
about -version;
// Result: 2018 //
about -cutIdentifier;
// Result: 202004151615-e82ce49a8d //
about -osv;
// Result: Microsoft Windows 8 Enterprise Edition, 64-bit (Build 9200)
arnoldExportAss -f "//nonews/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/Vegetation.ass" -s -expandProcedurals -shadowLinks 0 -mask 6385 -lightLinks 0 -exportAllShadingGroups -boundingBox -fullPath-cam perspShape;
file -q -exn;
// Result: //nonews/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/Vegetation 03.mb //
getPanel -scriptType renderWindowPanel;
// Result: renderView //
stopIprRendering renderView;
import mtoa.utils;mtoa.utils._objectStore[2104617136984]()
# Result: False #
renderer -materialViewRendererSuspend true;
import mtoa.utils;mtoa.utils.getSourceImagesDir()
# Result: [u'//nonews/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/sourceimages'] #
import maya.cmds as cmds;cmds.workspace(query=True, rootDirectory=True)
# Result: u'//nonews/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/' #
// Warning: arnold_bifrost.dll was compiled against non-compatible Arnold 6.0.0.0 //
prepareRender -setup;
prepareRender -invokePreRender;
colorManagementPrefs -q -cmEnabled;
// Result: 1 //
colorManagementPrefs -q -outputTransformEnabled;
// Result: 0 //
internalVar -userPrefDir;
// Result: C:/Users/Jesus/Documents/maya/2018/prefs/ //
colorManagementCatalog -queryUserTransformPath;
// Result: C:/Users/Jesus/Documents/maya/synColor/Shared/ //
ls -sl -typ shadingEngine;
// Result: 1 //
// Result: 0 //
// Result: 1 //
colorManagementPrefs -q -renderingSpaceName;
// Result: scene-linear Rec 709/sRGB //
import mtoa.makeTx; mtoa.makeTx.expandFilename('//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/tree_01_steam.jpg')
# Result: ['//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/tree_01_steam.jpg'] #
import mtoa.makeTx; mtoa.makeTx.expandFilename('//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/tree_01_level_opacity.jpg')
# Result: ['//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/tree_01_level_opacity.jpg'] #
import mtoa.makeTx; mtoa.makeTx.expandFilename('//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/tree_01_level.jpg')
# Result: ['//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/tree_01_level.jpg'] #
import mtoa.makeTx; mtoa.makeTx.expandFilename('//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/tree_02_steam.jpg')
# Result: ['//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/tree_02_steam.jpg'] #
import mtoa.makeTx; mtoa.makeTx.expandFilename('//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/tree_02_level.jpg')
# Result: ['//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/tree_02_level.jpg'] #
import mtoa.makeTx; mtoa.makeTx.expandFilename('//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/tree_02_level_opacity.jpg')
# Result: ['//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/tree_02_level_opacity.jpg'] #
import mtoa.makeTx; mtoa.makeTx.expandFilename('//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/tree_01_steam_bump.jpg')
# Result: ['//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/tree_01_steam_bump.jpg'] #
import mtoa.makeTx; mtoa.makeTx.expandFilename('//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/Groundplants0041_2_S.jpg')
# Result: ['//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/Groundplants0041_2_S.jpg'] #
import mtoa.makeTx; mtoa.makeTx.expandFilename('//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/tree_01_steam.tx')
# Result: [] #
import mtoa.makeTx; mtoa.makeTx.expandFilename('//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/tree_01_level_opacity.tx')
# Result: [] #
import mtoa.makeTx; mtoa.makeTx.expandFilename('//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/tree_01_level.tx')
# Result: [] #
import mtoa.makeTx; mtoa.makeTx.expandFilename('//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/tree_02_steam.tx')
# Result: [] #
# Result: [] #
import mtoa.makeTx; mtoa.makeTx.expandFilename('//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/tree_02_level.tx')
# Result: [] #
import mtoa.makeTx; mtoa.makeTx.expandFilename('//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/tree_02_level_opacity.tx')
# Result: [] #
import mtoa.makeTx; mtoa.makeTx.expandFilename('//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/tree_01_steam_bump.tx')
# Result: [] #
import mtoa.makeTx; mtoa.makeTx.expandFilename('//NoneWS/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/textures/Groundplants0041_2_S.tx')
# Result: [] #
# Result: [] #
# Result: [] #
# Result: [] #
# Result: [] #
prepareRender -invokePostRender;
prepareRender -restore;
file -q -exn;
import mtoa.utils;mtoa.utils.getFileName(1, 'RenderPass=beauty RenderLayer=defaultRenderLayer Camera=persp Extension=exr Scene="Vegetation 03"', frame=1, path=r'w:\mecagoendios', fileType='images', strictAOVs=True, createDirectory=True);
exists renderLayerDisplayName;
// Result: 1 //
renderLayerDisplayName masterLayer;
// Result: masterLayer //
# Error: line 1: WindowsError: file C:\Program Files\Autodesk\Maya2018\bin\python27.zip\os.py line 157: 5 #
// Result: 1 //
# Result: [] #
# Result: [] #
# Result: [] #
# Result: [] #
# Result: [] #
# Result: [] #
# Result: [] #
# Result: [] #
# Result: [] #
# Result: [] #
# Result: [] #
# Result: [] #
# Result: [] #
import mtoa.utils;mtoa.utils.getFileName(1, ' RenderLayer=defaultRenderLayer Camera=persp Extension=ass Scene="Vegetation 03"', frame=1, path=r'//nonews/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/Vegetation', fileType='ASS', isSequence=False, createDirectory=True);
// Result: 1 //
# Result: '//nonews/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_Times.Square/Maya/scenes/Vegetation.ass' #
import getpass; getpass.getuser();
# Result: 'Jesus' #
file -q -sn;
renderer -materialViewRendererSuspend false;
// Result: //nonews/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_Times.Square/Maya/scenes/Vegetation.ass //
memory -he -mb -af;
// Result: 5916.425781 //
memory -fr -mb -af;
// Result: 37176.695313 //
memory -pf;
// Result: 11382534 //
HfSaveSceneCallback false 1;
// Result: //nonews/W/CG Works/3D Products/Times Square/7th_Avenue_&_Broadway_from_45st_to_48st_[Times.Square]/Maya/scenes/Vegetation.ass //
fileCmdCallback;
// Result: 1 //
editMenuUpdate MayaWindow|mainEditMenu;
isDisplayingAllRendererTabs;
// Result: 0 //
rendererTabLayoutName "arnold";
// Result: arnoldTabLayout //
uiRes m_createMayaSoftwareCommonGlobalsTab.kNewFileName;
// Result: File name: ^1s //
uiRes m_createMayaSoftwareCommonGlobalsTab.kNewTo;
// Result: To: ^1s //
global string $gMeasurementUnitsNames[];
global proc string[] _mtoa_global_var_gMeasurementUnitsNamesArray() { global string $gMeasurementUnitsNames[]; return $gMeasurementUnitsNames; } _mtoa_global_var_gMeasurementUnitsNamesArray();
// Result: pixels inches cm mm points picas //
global string $gResolutionUnitsNames[];
global proc string[] _mtoa_global_var_gResolutionUnitsNamesArray() { global string $gResolutionUnitsNames[]; return $gResolutionUnitsNames; } _mtoa_global_var_gResolutionUnitsNamesArray();
// Result: pixels/inch pixels/cm //
convertPixelsToInches(960, 72.0);
// Result: 13.333333 //
convertPixelsToInches(540, 72.0);
// Result: 7.5 //
convertMeasurement(13.3333333333, "inches", "inches");
convertMeasurement(7.5, "inches","inches");
// Result: 7.5 //
convertResolutionMeasurement(72.0, "pixels/inch", "pixels/inch");
// Result: 72 //
setDecimalPrecision(13.3333333333, 1.0);
// Result: 13.3 //
setDecimalPrecision(7.5, 1.0);
// Result: 7.5 //
resolutionFormats_melToUI("inches");
// Result: inches //
setDecimalPrecision(72.0, 1.0);
// Result: 72 //
resolutionFormats_melToUI("pixels/inch");
// Result: pixels/inch //
uiRes m_createMayaSoftwareCommonGlobalsTab.kNewImageSize;
// Result: Image size: ^1s x ^2s (^3s x ^4s ^5s ^6s ^7s ) //
changeToolIcon;
dR_contextChanged;
currentCtx;
// Result: moveSuperContext //
if(`exists dR_updateCommandPanel`) dR_updateCommandPanel;
dR_updateToolSettings;
HfDeleteExtraFurGlobals;
