Export STEP file to FreeCad
martinndubstep
Message 1 of 8
martinndubstep
Hello, I've done nice project in Autodesk Maya and I asked my friend if he could mill it on his cnc machine. He asked me for .stp file. I knew It has to do smth with AutoCad so I've downloaded FreeCad. I would like to export my project from Maya in a STEP file and import it into FreeCad without creating the project from scratch in FreeCad.
Here's what I do.
In Maya: Export all -> STEP_ATF
But when I import this file into FreeCad it doesn't anything.
Also when I try to import this stp file into Maya it doesn't show anything either.
I attach maya file of the project - https://drive.google.com/open?id=1FIxcRj2vFcqqmgrcjwnoLTk53_AicmtA
Thank you for help.
Replies (7)
Message 2 of 8
mspeer
Hi!
If i remember correct, this is a bug in Maya 2018.
Message 3 of 8
martinndubstep
Okay, so is there a way to fix it?
Message 4 of 8
mspeer
Hi!
I recommend to install the latest version of Maya 2019.
Message 5 of 8
martinndubstep
I got newest Maya 2019. Still, I have a problem importing this project to freecad to get stepfile. Can you try it on your computer? I've put the link to my file in the topic. Thanks
Message 6 of 8
martinndubstep
Again, I have 2 plates in program here - https://drive.google.com/open?id=1m6gvyiAuHRL6FsF1RKspsBQAvbMTgvP-.
I want to get .stp file of each plate to be able to make them on cnc machine. I can not do that. I've dowloaded autocad 2019 trial edition and when I import stp file from Maya It shows text or something not object
Message 7 of 8
mspeer
Hi!
Your scene does not contain any nurbs objects.
To export polygon objects, use an other format like .OBJ or STL.
Message 8 of 8
martinndubstep
I think I've solved my problem. Exporting file into obj and then importing to autocad did work.
Thank you!
