How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Hello everyone
I am newbie in Maya just started learning it 1 week ago , so don't please get mad if I say something stupid 🙂
Yesterday I got a problem with Maya , when I load my scene everything lost the colors became grey and one part for some reasons white.
Here is a screen shot
I tried to google about it already 2 hours , but I give up , that's why I am making my post. I tried already to switch on/off all the hot keys , change viewport and etc., but nothing helps colors don't come back there should be on back image it's completely hidden too. I have suggestion that something happened with my graphic card. Because in "Output Window" of Maya there is written :
Initialized VP2.0 renderer {
Version : 2016.3.18.11. Feature Level 5.
Adapter : GeForce GTX 960M/PCIe/SSE2
Vendor ID: 4318. Device ID : 6427
Driver : .
API : OpenGL V.4.5.
Max texture size : 16384 * 16384.
Max tex coords : 32
Shader versions supported (Vertex: 5, Geometry: 5, Pixel 5).
Shader compiler profile : (Best card profile)
Active stereo support available : 0
GPU Memory Limit : 2048 MB.
CPU Memory Limit: 7667.07 MB.
OpenCL evaluator is attempting to initialize OpenCL.
Unable to detect NVidia driver version. Disabling asynchronous read-back for OpenCL.
Detected 2 OpenCL Platforms:
0: Intel(R) Corporation. Intel(R) OpenCL. OpenCL 2.0 .
Supported extensions: cl_intel_dx9_media_sharing cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_d3d11_sharing cl_khr_depth_images cl_khr_dx9_media_sharing cl_khr_gl_sharing cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_image2d_from_buffer cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_spir
1: NVIDIA Corporation. NVIDIA CUDA. OpenCL 1.2 CUDA 8.0.0.
Supported extensions: cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts
OpenCL evaluator choosing OpenCL platform NVIDIA Corporation.
Choosing OpenCL Device GeForce GTX 960M. Device Type: GPU Device is available.
I/O warning : failed to load external entity "file:///C:/Users/Vladlen/Desktop/Maya%20Projects/maya_intro_2017/scenes/end_dustShape.xml"
I/O warning : failed to load external entity "file:///C:/Users/Vladlen/Desktop/Maya%20Projects/maya_intro_2017/scenes/start_dustShape.xml"
API error detected in S:\Maya_2017_DI\src\Maya\src\Components\BifrostTmp\plugins\mayavis\BFPlugin.cpp at line 61
: (kFailure): Unexpected Internal Failure
API error detected in S:\Maya_2017_DI\src\Maya\src\Components\BifrostTmp\plugins\mayavis\BFPlugin.cpp at line 74
I already checked all the drivers updates , computers updates , tested graphic card it self - nothing seems wrong. I can't proceed with learning Maya because of that 😞 I hope somebody can help me , I really want to come back to my work.
Hi!
If it worked before and you can view new textures assigned to materials on new objects it's not the graphic card, although it's strange that the nvidia driver version will not be detected.
Please open Windows -> Rendering Editors Hypershade -> and check if the textures assigned to your materials still point to a valid path.
You also can use Windows -> General Editors -> File Path Editor for a quick overview and corrections of file paths.
It's also possible to override the texture display per object/layer (Drawing Overrides -> Texturing / Drawing Override Options -> Texturing).
Thank you , your post was really helpful! For some reasons my path in Windows -> Rendering Editors >Hypershade was for some colours diffrent , but after changing it didn't solve anything , but Windows -> General Editors -> File Path Editor was showing no problems and anyway I was thinking to try to push bottom "Auto-Resolve" and it fixed it. Thank you
How to buy
