Hello everyone
I am newbie in Maya just started learning it 1 week ago , so don't please get mad if I say something stupid 🙂
Yesterday I got a problem with Maya , when I load my scene everything lost the colors became grey and one part for some reasons white.
Here is a screen shot
I tried to google about it already 2 hours , but I give up , that's why I am making my post. I tried already to switch on/off all the hot keys , change viewport and etc., but nothing helps colors don't come back there should be on back image it's completely hidden too. I have suggestion that something happened with my graphic card. Because in "Output Window" of Maya there is written :
Initialized VP2.0 renderer {
Version : 2016.3.18.11. Feature Level 5.
Adapter : GeForce GTX 960M/PCIe/SSE2
Vendor ID: 4318. Device ID : 6427
Driver : .
API : OpenGL V.4.5.
Max texture size : 16384 * 16384.
Max tex coords : 32
Shader versions supported (Vertex: 5, Geometry: 5, Pixel 5).
Shader compiler profile : (Best card profile)
Active stereo support available : 0
GPU Memory Limit : 2048 MB.
CPU Memory Limit: 7667.07 MB.
OpenCL evaluator is attempting to initialize OpenCL.
Unable to detect NVidia driver version. Disabling asynchronous read-back for OpenCL.
Detected 2 OpenCL Platforms:
0: Intel(R) Corporation. Intel(R) OpenCL. OpenCL 2.0 .
Supported extensions: cl_intel_dx9_media_sharing cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_d3d11_sharing cl_khr_depth_images cl_khr_dx9_media_sharing cl_khr_gl_sharing cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_image2d_from_buffer cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_spir
1: NVIDIA Corporation. NVIDIA CUDA. OpenCL 1.2 CUDA 8.0.0.
Supported extensions: cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_d3d10_sharing cl_khr_d3d10_sharing cl_nv_d3d11_sharing cl_nv_copy_opts
OpenCL evaluator choosing OpenCL platform NVIDIA Corporation.
Choosing OpenCL Device GeForce GTX 960M. Device Type: GPU Device is available.
I/O warning : failed to load external entity "file:///C:/Users/Vladlen/Desktop/Maya%20Projects/maya_intro_2017/scenes/end_dustShape.xml"
I/O warning : failed to load external entity "file:///C:/Users/Vladlen/Desktop/Maya%20Projects/maya_intro_2017/scenes/start_dustShape.xml"
API error detected in S:\Maya_2017_DI\src\Maya\src\Components\BifrostTmp\plugins\mayavis\BFPlugin.cpp at line 61
: (kFailure): Unexpected Internal Failure
API error detected in S:\Maya_2017_DI\src\Maya\src\Components\BifrostTmp\plugins\mayavis\BFPlugin.cpp at line 74
I already checked all the drivers updates , computers updates , tested graphic card it self - nothing seems wrong. I can't proceed with learning Maya because of that 😞 I hope somebody can help me , I really want to come back to my work.
