# Error: ModuleNotFoundError: file <maya console> line 1: No module named 'pymel'
amaterasu-qbb
amaterasu-qbb
Hi!
I'm using Windows 10 and trying to install Pymel to use with Maya 2024, but I'm getting error messages like the one in the title, probably because I didn't install it correctly. How can I get Pymel to work?
I tried restarting Maya by running cmd or command prompt in the folder C:\Program Files\Autodesk\Maya2024\bin
and type the following command.
mayapy -m pip install --user install pymel
A folder that would be the Pymel was installed in the \AppData\Roaming\Python.
Script folder and the pymel folder. These folders were manually moved to C:\Program Files\Autodesk\Maya2024\bin
folder that moved.folder that moved.
Any advice would be helpful.
amaterasu-qbb
Problem solved.
Install the latest version of Python 3.11.4 as of 6/15/2023.
Go to https://pypi.org/project/pymel/ to find the version of pymel that Maya supports and install it. Version 1.4.0 is Maya 2024 compatible. Press CTRL + L in any explorer location to get to the address bar and type,
cmd
Run,
pip install --user pymel
This will install a site-packages folder in Roaming\ Python 311. Two pymel files will be installed in that folder.
Or you can run
pip install pymel
C:\Users\student\AppData\Local\Programs\Python\Python311\Lib\Site-packages with two pymel files in the site-packages folder.
If you have already run pip install --user pymel, manually move the site-packeges folder to the Scripts folder in the Maya Scripts folder in the documentation.
If you have already run pip install pymell, create a site-packeges folder in Maya's scripts folder in the documentation, and manually move the pymel folder, pymel-1.4.0.dist-info folder to the scripts folder.
Note that in both cases the two folders, the pymel folder and the pymel-1.4.0.dist-info folder, must be in the site-packeges folder.
cmd result.cmd result.under the site-packages there are two folder.under the site-packages there are two folder.
I used the target command to download the site-packeges folder containing the pymel folder and the pymel-1.4.0.dist-info folder to the Maya Scripts folder in the documentation, but it made no sense.
This is really weird. Please comment if you know how to do it.
I wrote the same in this link.
https://forums.autodesk.com/t5/maya-forum/pymel-not-included-in-maya-2024/m-p/11891657/highlight/fal...
lucas.signoles
Observer
Observer
Thank you so much !!
amaterasu-qbb
You're welcome. happy programming.
dikaqq
Community Visitor
Community Visitor
if u're using maya 2023, you need to follow this video on how to installing pymel
https://www.youtube.com/watch?v=2LA2dQ6A5ss
