error message
error message
error message
hi
im a student in animation and modelisation and the deadline for my project is tomorrow but whenever i try to open my project, on my house computer or on my laptop the following message appear:``Errors have occurec while reading this scene that may rsult in data loss. Please check the script editor for detail.``
since im new with maya i don't understand what the writing in the output window mean so i would like if someone could help me with that.
thanks.
here's what written in the output window:
Initialized VP2.0 renderer {
Version : 6.3.16.0. Feature Level 5.
Adapter : Intel(R) HD Graphics
Vendor ID: 32902. Device ID : 342
Driver : igd10iumd64.dll:10.18.10.3308.
API : DirectX V.11.
Max texture size : 16384 * 16384.
Max tex coords : 32
Shader versions supported (Vertex: 5, Geometry: 5, Pixel 5).
Active stereo support available : 0
GPU Memory Limit : 2054.86 MB.
CPU Memory Limit: 3782.63 MB.
OpenCL evaluator is attempting to initialize OpenCL.
Detected 1 OpenCL Platforms:
0: Intel(R) Corporation. Intel(R) OpenCL. OpenCL 1.2 .
Supported extensions: cl_intel_dx9_media_sharing cl_khr_byte_addressable_store cl_khr_d3d11_sharing cl_khr_dx9_media_sharing cl_khr_gl_sharing cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics
OpenCL evaluator choosing OpenCL platform Intel(R) Corporation.
Choosing OpenCL Device Intel(R) HD Graphics. Device Type: GPU Device is available.
OpenCL device does not support out of order execution
damaggio
Is your Mya house version the same at school?
no, at school its maya 2015 and i have maya 2016
damaggio
Sometimes you can still continue working with a scene without any problems as long as the scene opens , I have a scene like that I've been working for a month and everything is fine...as an example of the same warning, if I have Vray in the scene and try to open the file in another computer without VRay it will give me that warning message...it could be many different things specially 2016 back to 2015 because 2016 has alot of new features.
Just in case work in .ma file and avoid .mb files.
But what can I do if I can't open the scene? is there a way to make it work?
damaggio
It's not opening now?
damaggio
You can try to export the scene as FBX and import in a fresh new scene....you should also always have a back up as well and use incremental save.
