Error: <function selCom at 0x7f29c5c04aa0>;
info
Message 1 of 35
info
Hi all, I got a few object in a scene, when I try to select some of them in outliner  I receive the following error
select -r HairBasefrom_Zbrush03 ;
// Error: <function selCom at 0x7f29c5c04aa0>; //
// Error: Line 1.1: Syntax error //
I have try to export in fbx and re import in a fresh new scene/ optimize the scene / delete history
nothing happen.
thx
edit. I noticed that's happen if I create a cube in a new scene.. help
Replies (34)
Message 2 of 35
mspeer
Hi!
Try a reset of your preferences.
Rename the folder prefs in folder 2019 to something like prefs_backup, or to reset everything, the folder 2019 to 2019_backup (or even the maya folder to maya_backup). Maya creates new folders (don't copy preferences from previous Maya versions). Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
Then test again with a new scene.
Message 3 of 35
info
Hi, thank you for your reply.
I had try to delete just prefs folder before this post. I never thought to delete the 2019  folder.
so now the error it's disappear, thanks man
Message 4 of 35
ninhenzo64
I found it's some outliner callback in here:
Z:/Documents/maya/2018/prefs/workspaces/Maya_Classic.json
Message 5 of 35
info
sorry but seems that this solution doesn't work. I deleted the entire folder maya 2019. but the error still remain
Message 6 of 35
mspeer
Hi!
Please be more precise, you said the error was gone, was this a mistake or was this correct and it appears now again, that's a difference.
Maybe there is a problem in one of your scenes or you added again a custom script,...
Message 7 of 35
info
Hi, sorry for my bad english 🙂
was this correct and it appears now again because  I added again a custom script.
Message 8 of 35
mspeer
Hi!
It's not the englisch.
Based on your last posts, the problem was solved
and reappeared because of
1. A somehow corrupted scene
2. A custom script
3. A bug related to some Preferences settings.
Just again reset the Preferences to find out's what's causing it.
Message 9 of 35
info
Hi, thanks  for your support.
  1. I’ve try to reset the maya 2019 folder again. And I’ve reimport the scripts and some older stuff from previous folder’s back up, one of one to check in whar’s cause the problem.   All fine, no more error. The error appear when open a scene that I have to work.. it’s a cad file exported . Maybe some odd name in some pieces. there’s  a way to find what cause this problem . A debug ? I don’t know . Thanks anyway
Message 10 of 35
mspeer
Hi!
If it's a scene specific problem, please provide the scene-file.
Message 11 of 35
info
I started a new project, so i reset my 2019 folder. and the problem appear again, so it's not releated to a scene specific
Message 12 of 35
ninhenzo64
I'm pretty sure it's a maya bug, to do with classic view set up in this file
It looks like that's where the selCom command is declared.
Message 13 of 35
ninhenzo64
My whole studio is getting it, for the most part we just ignore it
Message 14 of 35
mspeer
Hi!
Your information is a bit confusing:
2. I started a new project, so i reset my 2019 folder. and the problem appear again.
"The error appear when open a scene that I have to work"
For me this looks like a scene-specific problem, maybe coupled with a specific custom layout. Without a scene-file and the layout settings i can't help you further.
You could also try a newer version of Maya
Message 15 of 35
ninhenzo64
we're getting this in maya 2018 and 2019, even in an empty scene, it's triggered by changing the selection in the outliner
you can use this code to find outliners with bad callbacks
from maya import cmds
for _editor in cmds.lsUI(editors=True): if not cmds.outlinerEditor(_editor, query=True, exists=True): continue _sel_cmd = cmds.outlinerEditor(_editor, query=True, selectCommand=True) if not _sel_cmd: continue print _editor, _sel_cmd
this is the output i'm getting:
outlinerPanel1 <function selCom at 0x7f29c5c04aa0>
outlinerPanel1Slave <function selCom at 0x7f29c5c04aa0>
it looks like maya's tring to set the outline selectCommand callback to a python function, but when it gets put in the json file the callback is converted to text which maya then tries to interpret as mel.
I fixed the issue by editing this file while maya was closed:
Z:\Documents\maya\2018\prefs\workspaces\Maya_Classic.json
I removed this chunk of code:
-selectCommand \"<function selCom at 0x7f29c5c04aa0>\"
BTW the preview button is broken on this page
Message 16 of 35
ninhenzo64
here's an easier fix
        continue
    if not _sel_cmd or not _sel_cmd.startswith('<function selCom at '):
        continue
    cmds.outlinerEditor(_editor, edit=True, selectCommand='pass')
Message 17 of 35
sulkybunny
Hi there..
having the same issue after using custom scripts on a cha7ratcer
this last bit u refer to : “easier fix”
is that Also within
Maya_Classic.json
did that eliminate the issue for you ?
Message 18 of 35
ninhenzo64
no, this is python to run in the script editor. actually i found an issue with the last fix - it fixes the current session but then when maya shuts down it translates the python to mel and saves that to the Maya_Classic.json file. this is a better fix as it can be interpreted as mel or python:
        continue
        continue
    cmds.outlinerEditor(_editor, edit=True, selectCommand='print("")')
Message 19 of 35
nelsoncruz
Hey,  Would it be possible to share the custom script that is being used?  I am trying to track this down further on my end.
Nelson Cruz
Manager, Software QA Engineering
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 20 of 35
ninhenzo64
@nelsoncruz I'm pretty sure this isn't due to a custom script - I'm getting this with maya 2019 at home and with a number of artists using maya 2018 at my studio (including myself). It seems to be related to saving changes to workspaces, the dropdown in the top right of the maya interface. Maya sets the selectCommand callback on the outliner to a python function called "selCom". This works fine in the current session, but this change is also saved to a json file in preferences, which saves the selectCommand as the python converted to a string - eg. "<function selCom at 0x7f29c5c04aa0>". When you relaunch maya, the outliner selectCommand is restored from the json file, which maya then tries to interpret as mel, causing the error we're seeing.
