Error: [gpu] no GPU matching requirements found for GPU-rendering
Piranut_i
Piranut_i
I try to use arnold renderer with my GPU 4060 ti but it error "// Error: [gpu] no GPU matching requirements found for GPU-rendering //" I try to fix it out by myself. I already update my graphic drivers , check CUDA , check nvidia control panel setting and check arnold setting. In Arnold setting it already have my gpu but it still error. Thx for your helps.
Christoph_Schaedl
Are you on a laptop with a onboard graphics card?
If yes make sure Maya does start with the geforce.
https://linktr.ee/cg_oglu
Piranut_i
No, I use a PC.
Piranut_i
Now, I'm using Maya 2025 and now I can render with GPU in Arnold Render View with no errors, but I still can't render in Render Sequence by the same issue // Error: [gpu] no GPU matching requirements found for GPU-rendering //
Christoph_Schaedl
Are you on the latest MtoA version?
