Announcements
edit curve menu
markt56
edit curve menu
markt56
help. In Maya I cannot find the edit curve menu in Maya 2016.
Mark Tabibian
Replies (7)
damaggio
Is it Curves>Edit Curve tool?
markt56
Thanks for the reply! I can't find curves edit tool anywhere. I have all the curves but can't find the edit curve. F1Maya help is no good. Went thru the UI preferences to no avail. Even tried youtube.
Mark
Sent from Surface
pshwayka
markt56
ahhh thank you so much!! I was in the wrong menu. Odviously I am a newbie.
Mark
pshwayka
No problem Mark. Let us know if you get stuck again!
abars51099
But at this link:
https://knowledge.autodesk.com/support/maya-lt/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/MayaL...
The documentation indicates that there are sub-menus under the edit curve option -- and when I click on edit curve tool, I don't see any sub-menu.
Moreover, when I do ctl+rmb, I just see a minus sign.
damaggio
Under Curves>Edit Curve Tool...if you don't have this maybe you should reset your preferences.
