Edges look white instead of green
ricky_rigourd
Observer Observer
ricky_rigourd
Observer
Observer
I did an unsmooth in the character model an now all edges look white. I want to start cutting for the UV but I can't.
If I select another object its edges look green.
Another thing I tried was to import the model before unsmoothing it with "mesh>Unsmooth" but when I try to import it nothing happens.
I don't know how to have all the edges green .
damaggio
All your UV faces are separated.the white edges are from Show UV seams.You can uncheck that in the UV editor, is off by default.Once you start doing the final Uvs it will go back to normal.
ricky_rigourd
Observer
Observer
Thanks.
After your message I did a planar, selected the object and could sew everything together, then I could start cutting the UVs.
