Easy Animation with delay
k.naghshineh
k.naghshineh
Hi there,
Im sure there is a pretty simple solution to this. Although we all know lovely Maya.
I have three  objects [obj1, obj2, obj3] next to each other in space. When animating obj1s translate, I want obj2 & obj3 to follow smoothly and ease into the ending positon with an (adjustable) delay. Kind of magnetic-hovering action, if that make sense.
There are some posts in the forum on using expressions or the cacheframeNode. I could not get it to work properly with neither methods.
Thank you in advance
patrick.schock
Autodesk Support
Autodesk Support
Hi @k.naghshineh,
maybe a MASH delay setup could work for you. See here: Maya: MASH Delay.
Hope this helps!
Best regards,
Patrick
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
