Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Does anyone know why an asset would appear invisible when imported into a scene
2 REPLIES 2
Peteman12
698 Views, 2 Replies
I'm getting this weird issue where when I import a particular asset into a scene in Maya, the asset does not appear to be visible in the scene. Everything else about it is normal (it has attributes, hierarchies, etc), but I can't see it. Does anyone know what might be going on?
If I import the asset into an empty scene, nothing goes wrong.
2 REPLIES 2
Peteman12
in reply to: Peteman12
Turns out we were using render layers and the assets weren't being imported into it.
All we'd need to do is import it into the render layer
lynn_zhang
Hi @Peteman12
Glad to hear you fixed the problem and thanks so much for sharing the solution! This will benefit other users in the community with the same issue.
Lynn Zhang
