Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Dividing the mesh
3 REPLIES 3
834 Views, 3 Replies
Dividing the mesh
I'm doing the UVMapping tutorial. I've gotten the arms and legs mesh extracted. When I try to extract the torso mesh, I get a message saying "Error: line 0: Polysurface5 has only one piece. Ignored."  I've included a screenshot that shows the message. Any help will be appreciated. Thanks!
3 REPLIES 3
damaggio
The vest is its on piece already sherif, there's nothing to be extracted, all you have to do is UV the vest , cut the seams and sew the correct seems again if necessary and unfold....the usual steps, should be very easy to do , is  a very simple object.
Good luck.
damaggio
in reply to: damaggio
Even if the vest had been combined to the body previously , you could if you wanted extract as a separate model "as it was once"..or....you can select all the vest faces and UV map them with the mesh still combined to the body....off course separating the mesh would be a better option to keep things organized.
If I had half a brain, I would have realized that the vest was already done. Thanks!
