DirectConnect in Maya 2018
Hey People,
I would like to import a dwg document from AutoCad to Maya.
It seems that i have to go to Maya- windows-settings-plugin manager.
But it is not installed!
It is appeared this website http://usa.autodesk.com/adsk/servlet/pc/index?siteID=123112&id=14561470 but it directs me to https://www.autodesk.com/products/alias-products/features.direct.connect.data.transfer.
I try to find out how i could down load the DirectConnect but I cannot find out.
Could you please assist me.
Athanasios
mspeer
Hi!
Direct Connect is replaced by ATF.
Thank you for you reply , but what is it the ATF.
Could you please specify in details, i am not so familiar with the program.
Thank you again.
mspeer
Hi!
Autodesk ATF:
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Maya-Dat...
It's installed by default with Maya 2018, please check load state in Plug-in Manager.
Confirmed - Maya 2018 accepts STL files dropped into the viewport when ATF Plugin is enabled.
