Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Detected 2 OpenCL Platforms
1 REPLY 1
1029 Views, 1 Reply
I have a problem with the graphics cards (it has 2) with this laptop - Lenovo ideapad 500. It's stuck at the output window and can't make it open.
in the output windows it shows the next:
Initialized VP2.0 renderer {
Version : 6.3.16.0. Feature Level 4.
Adapter : AMD Radeon(TM) R7 M360
Vendor ID: 4098. Device ID : 6422
Driver : .
API : OpenGL V.4.5.
Max texture size : 16384 * 16384.
Max tex coords : 16
Shader versions supported (Vertex: 4, Geometry: 4, Pixel 4).
Shader compiler profile : (Best card profile)
Active stereo support available : 0
GPU Memory Limit : 2048 MB.
CPU Memory Limit: 11539.4 MB.
OpenCL evaluator is attempting to initialize OpenCL.
Detected 2 OpenCL Platforms:
0: Intel(R) Corporation. Intel(R) OpenCL. OpenCL 2.0 .
Supported extensions: cl_intel_dx9_media_sharing cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_d3d11_sharing cl_khr_depth_images cl_khr_dx9_media_sharing cl_khr_gl_sharing cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_image2d_from_buffer cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_spir
1: Advanced Micro Devices, Inc.. AMD Accelerated Parallel Processing. OpenCL 2.0 AMD-APP (1800.5).
Supported extensions: cl_khr_icd cl_khr_d3d10_sharing cl_khr_d3d11_sharing cl_khr_dx9_media_sharing cl_amd_event_callback cl_amd_offline_devices
OpenCL evaluator choosing OpenCL platform Advanced Micro Devices, Inc..
I have tried to disable one of the 2 graphics card, but when i do it, the computer is extremely slow. Is there any way i can make it work?
Thank you!
1 REPLY 1
I have the same laptop and I had Maya working and then windows 10 had a update and I had exactly the same problem, you need to go o the AMD website and update your drivers for your graphics card.
