Dash not working?
Dash not working?
Parmenides
Dash not working?
Parmenides
I am not able to get Dash to work. I can option-right click in any channel and put in r(30) or whatever but Return or Enter doesn't complete it.  Deleted prefs, no difference.
Maya 2027.1 Mac
brentmc
We have reproduced and logged the issue internally.
Thanks.
Brent McPherson
Principle Software Developer
afatka
Is there a fix or a workaround for this?
Or is there another way to leverage DASH?
Parmenides
Still doesn't work for me either.
 "# AttributeError: type object 'DashCommand' has no attribute 'dashLinear'"
brentmc
There issue is in DashCommand.py so the safest option is to wait and check to see if it is addressed in the next release.
Alternatively, you could feed the error into CoPilot/Claude/your-AI-of-choice and it should be able to patch DashCommand.py in the Maya install to work around the issue.
Brent McPherson
navya_gelli
Hello @afatka,
A possible workaround was suggested in a previous reply. Could you let us know if that workaround was helpful or if you're still experiencing the issue? If this workaround resolved the issue for you, consider sharing your confirmation in the thread. It may also help others facing the same problem.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot.
Navya Gelli
afatka
I played with it a little bit in Gemini with no luck - If I get more time later, I'll try again...but it might just be that I'll have to wait for an official update. Hopefully we don't have to wait too long...
