Announcements
ctrl-click to select multiple items in outliner not working maya 2016
Using maya 2016 SP6 for mac with 2-button mouse tracking set in preferences since I'm using a trackpad.
Selecting multiple (non-contiguous) items with ctrl+click or cmd+click works as expected with 3-button mode set.
Selecting multiple (contiguous) items with shift+click works as expected.
Selecting multiple items with ctrl+click or cmd+click DOES NOT work with 2-button tracking set.
This worked fine in previous versions of maya (e.g. maya 2014).
This is a serious impediment to my workflow and happens constantly - I need to select things in the outliner every few seconds to work.
pshwayka
I have a 3-button mouse, but if I set it to 2-button tracking I'm able to use command+rmb to select non-contiguous items in the outliner. Have you tried that?
Hi Pshwayka,
Ah! That works and helps a lot - thank you.
I wonder, is that a bug or by design? No other list control I've ever used works like that.
Thanks a lot,
Barry.
pshwayka
What is interesting is, I have Maya 2014, 2015, and 2016 on the Mac I'm using...and in 2-button mode I can only select multiple non-contiguous items with command+RMB. (I'm running El Capitan, which BTW is not supported for Maya yet.)
amonpan.2b
Community Visitor
Community Visitor
I use control + option + command for Maya 2020
n.barantsev
Community Visitor
Community Visitor
control+option+command doesn't work in my case for some reason
