Constant error message
Message 1 of 16
Hello everyone
I've recentely installed Maya 2017, but since I made adjustments about infinite CTRL-Z in the preferences, it keep showing me the same error message everytime I click somewhere with an object selected :
// Error: file: C:/Program Files/Autodesk/Maya2017/scripts/others/drInit.mel line 1961: Object '' not found. //
It hadn't iterfered with the modelling (yet), bit it is quite annoying
Thanks in advance
PS : Sorry for my bad English
Replies (15)
Message 2 of 16
janerikarud
I also got this error all the time, really annoying. 😞
Message 3 of 16
Same. It doesn't seem to affect anything, but the constant error message is distracting.
Message 4 of 16
Have you guys found a solution to this yet?
Message 5 of 16
Nope, still here...
Message 6 of 16
Someone said to delete everything in your Documents/maya folder. It worked for me. It seems that something gets corrupted in the project folder. Thanks!
Message 7 of 16
Still getting the error message. I don't know if you mean delete the individual project folder on which you are working, or if you mean delete all your projects out of the Documents folder.
Excelsior!
Eric Kunzendorf
Message 8 of 16
I'm a new user so I could safely delete the entire maya folder. It must be something that happens in the preferences. It will probably come back!
Message 9 of 16
I deleted the folder, the error message went away, but it came back.
Message 10 of 16
Still have the same error as well.
Message 11 of 16
This error occured when I opened an FBX file from an earlier version of maya, and I think it left some log entries and other files in the maya documents folder... I removed a few but still not sure which one was the exact cause for the issue, I'll keep you all updated
Message 12 of 16
"all you can do at this moment to get rid of the spam in the log is to re-launch modeling toolkit. if button on the right is grayed out you can always do it from "Mesh Tools > Show Modeling Toolkit"
Source: http://forums.autodesk.com/t5/maya-forum/maya-2017-installed-facing-differnt-problems/td-p/6469076
Message 13 of 16
// Error: file: C:/Program Files/Autodesk/Maya2017/scripts/others/drInit.mel line 1961: Object '' not found. me too
Message 14 of 16
I found the solution here
https://forums.autodesk.com/t5/maya-forum/maya-2017-installed-facing-differnt-problems/td-p/6469076
The problem is, Maya is trying to find something that has not been set up as part of your workspace.
But if you open Maya, go to Mesh Tools > Show Modelling Toolkit
Then under Preferences, press Save and restart Maya.
It worked for me, so hope it works for your guys 🙂
Message 15 of 16
jacksonlmurtha
 Hello Autodesk WOULD YOU HELP ME, OTHER DAYS I KEEP GETTING ERRORS
Message 16 of 16
I too faced similar errors several times, but then I went to the prefernce and activated all the plugins and it worked
