Connection Editor Blank Spaces
Gen_T
Gen_T
I'm using Maya 2015 ext+SP5 on a Windows 7 Pro machine and I'm seeing some attributes blanked out.  They're there and clickable, just no label.  I've tried the default prefs and still the same. I've attached a screenshot of the problem.  Default prefs, new scene, I simply dragged the default lambert onto the default particle cloud shader.  Has anyone had this problem?
Edit: Solved
Forgot that I had edited the MayaStrings file to make fonts bigger and apparently something went wrong.  Tried the backup file and the problem went away!
pshwayka
Ha! I saw your large fonts and wondered if that was it.  Good thinking!
Gen_T
Yep, found the culprit. I guess it happened during experimenting with font sizes of 14 and 16 because the offending value was 146! Small typo, major pain lol.
