Does anybody know how to setup command line rendering for 2018 w/ Arnold?I have a huge single frame rendering I’m doing and need to render in segments because the program crashes when I do it at once. I’ve done it with Mental Ray but I don’t see the commands for Arnold.
Solved by Stephen.Blair. Go to Solution.
If you're rendering a Maya scene, then you use the render command.
render -r arnold -h
or
https://docs.arnoldrenderer.com/x/hAxkAg
Thanks! It works just like Mental Ray, except I can't get the progress flag to work. Prior I used '-v 5' to see % complete. is there a corresponding flag for Arnold?
Yes, -ai:lve
https://arnoldsupport.com/2018/03/28/mtoa-arnold-batch-rendering-flags/
