Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Channel box fields are red - what does this mean?
5 REPLIES 5
21245 Views, 5 Replies
I'm in the process of setting up a character rig and one of my control objects channel box fields are highlighted in red. This does not seem to be causing any problems so far but I am getting a little concerned that I could run into trouble further down the line. I've checked the user manual and it lists all sorts of colours that the channel box fields can have and their various meanings, but no mention of red! Any ideas??? What is it supposed to be communicating to me?
Num_T
5 REPLIES 5
what about keyframe? Select all channels and try to break connections.
uinsuton
Whatever channel is highlighted like the image I attached has that attribute keyed for animation. If you want to delete it or see other options just right click the highlighted channel for additional options. If you were not aware the "s" key is the hotkey for "setkey" which automatically keys all channels in the channel box, which you may have pressed accidentally.
Hope I was of some help
Many thanks! That was indeed the problem, must have pressed 'S' at some point - shame it wasn't mentioned along with all the other colours in the documentation...
satvamoliya
in reply to: uinsuton
Thank You Buddy.
brentmc
I checked and the red color is mentioned in the Channel Box documentation.
https://help.autodesk.com/view/MAYAUL/2024/ENU/?guid=GUID-4C954FB2-8B6A-4BBD-9695-DF432616D0D2
Brent McPherson
Principle Engineer
