Hi. I’m trying to use GPU for rendering instead of CPU setup of Arnold. But whenever I tried it, I only see a black render view with the notification that it’s uploading, even with a simple scene which my CPU can do in seconds. I’m using an i7 10700 with a GTX 1660. Thanks.
Solved by daunish. Go to Solution.
I'm not going to tell you to check your GPU drivers and Arnold's supported card list, I assume you've done that already.
Usually when you first run a GPU render it takes a really long time, so how long are you waiting before giving up?
You can speed the initial load time by, Arnold -> Utilities -> Pre-populate GPU Cache. That'll take some time then your scenes should load faster.
Let me know
