Can't display mesh as smooth with smooth shading
guitarjorge24
guitarjorge24
I imported a model from Blender which I exported as an OBJ. In Blender, I have the model display as "flat shaded" and exported it that way, but if  select to display it in Blender as "smooth shaded" it smooths it properly.
In Maya, the imported models looks flat shaded even when I select "Shading > Smooth Shade All" as you can see below:
I also tried to select the model and use "Mesh Display > Soften Edge" but it results in weird looking shading:
Here is what it looks like in Blender with Blender's flat shading (left) and Blender's smooth shading (right):
Abdulla-Qaladzay
Hi @guitarjorge24 šŸ¤šŸ‘‹
did you tried to unlock the normal
that looks the normals are locked
guitarjorge24
thanks for replying although that didn't work. I selected all the objects and hit Unlock Normals but still couldn't get smooth shading to work. I also selected all vertices in vertex mode and Unlocked again but didn't work either.
Any other ideas? Would it help if I upload my Maya file?
Abdulla-Qaladzay
yes  please upload the obj mesh
guitarjorge24
Hi, here is the obj I exported from blender
mspeer
Hi!
@Abdulla-Qaladzay  is correct, you need to unlock the normals, but based on the Blender Screenshot there is maybe some additional smoothing used in Blender, similar to Smooth Mesh Preview in Maya.
guitarjorge24
Ohh I didn't realize I had to do both, unlock and soften edges! Thanks!
