Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Can someone explain why this keeps happening
2 REPLIES 2
shayla_martin1
197 Views, 2 Replies
I will work on a project for hours saving normally (I have tried every saving method to get this to stop) opening and closing the program whenever I need to leave. Then One of the random times I open it back up it looks like this. I think I have remade this almost 12 times now. Random objects will appear in my workspace as well.
I have tried.
Maya 2023 at first which worked for the first part of my class. When it started doing that thing, I tried some fixes and it updated to 2024.
Same thing
I was told to try 2022
same thing
So I do not think it is me exactly because I have done nothing different since my first assignments and this started around the 4th or 5th.
Please and thank you for any help!!
2 REPLIES 2
That happend only once to me in 15 years of using maya. So this is a special case.
Could be corrupted prefs. Could be a corrupted maya install. Could be imported geo from an older project.
Could be a to big history stack. Could be everything.
I would start in a fresh scene and importing your geo as obj to get rid of all old maya info.
https://linktr.ee/cg_oglu
mspeer
in reply to: shayla_martin1
Hi!
Based on the screenshot I would guess this is an issue related to history.
Please delete construction history if not needed anymore.
