Can I set 'hide attributes' when I make new shader node in Hypershade?
Poor English. Sorry.
When I make new shader or something in hypershade, that will be made full attributes in node editor.
I want to change that setting. It means, I want to change default setting 'hide attributes' when I make new shader node in Hypershade.  (like image)
Could you please how to change and set default setting?
I know I can make that by using shortcut '1'. But I want to know set default setting.
sean.heasley
Hi @Anonymous
I don't believe there is a simple way to do this.
You would either need to edit internal files which I don't really recommend and/or write your own script.
Thanks for your kindness answer.
