bullet simulation error
Hello, Im using Maya 2019 version.
I have an error that says: "----Error: Failed to create evaluator for "drawdb/geometry/bulletRigidBodyShape" classification because the current drawing API isn't supported.----" when I click on the active rigid body under bullet.
Please tell me how to fix it, thank you!
Please answer in simple term, thank you
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
Thanks for posting! This issue seems similar to this post:
https://forums.autodesk.com/t5/maya-forum/bullet-simulation-error/td-p/7722416
Can you try those suggestions and let us know if the issue is resolved? 🙂
Thanks again for being a part of our community!
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
Just wanted to check in and see how things were going 🙂 Were you able to find a solution for this issue? If applicable, please consider sharing your strategy and mark the thread as solved so that others can find their answers easier.
Jordan Giboney
