*BUG* Maya not responding when saving (Using MASH)
Hey,
So I've come across a bug with MASH.
Maya becomes unresponsive when I go to save (both Save & Save As) after connecting a mesh to 'Input Mesh' in the MASH Distribute node.
It ONLY happens when the same object is used to start more than one MASH network. Using a separate object per network is a workaround.
It's 100% related to this series of actions, as I've saved after every step leading up to this point with no issue, just to make sure.
It's not fixed by switching file handling over to OS Native as well.
If anyone else is experiencing this, let me know. I've tried on two machines and have managed to replicate the same problem.
Stephanie
I found a fix after reading a few other posts:
Completely unload MTOA (Arnold) from the plugins manager, that fixes the problem.
Not a great solution though, as I render with Arnold. Reloading MTOA after seems to function fine though.
I'll post a reply if I come across any more issues in regards to this.
mspeer
Hi!
Maya version?
No problem here with Maya 2018 update 1.
