Hey,
I'm moving to linux and I have some issues with Autodesk software.
As you can see - when I open Maya the window is blank. But if I do ctrl+S then I can save this empty scene, with ctrl+O open it and Maya works fine then. I thought I could live with this workaroud untill I installed ShotGrid today and I am unable to loging using Web Login, the window is blank. What is causing this behaviour?
I am running Fedora 35. Terminal output when running maya:
Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
VP2 Warning : Graphics hardware has been detected to have insufficient memory (0 MB).
Please check your video card and driver to ensure that a minimum amount of memory exists (512 MB).
The environment variable MAYA_OGS_GPU_MEMORY_LIMIT can be used to explicitly set the GPU memory limit.
Initialized VP2.0 renderer {
Version : 2016.11.62.12. Feature Level 5.
Adapter : NVIDIA GeForce RTX 3090/PCIe/SSE2
Vendor ID: 4318. Device ID :
Driver : 4.6.0 NVIDIA 470.82.00.
API : OpenGL V.4.6.
Max texture size : 16384 * 16384.
Max texture coords : 32
Shader versions supported (Vertex: 5, Geometry: 5, Pixel 5).
Shader compiler profile : (Best card profile)
Active stereo support available : 0
Forced GPU Memory Limit : 2047 MB.
CPU Memory Limit : 122230 MB.
MultiDraw consolidation : enabled
OpenCL evaluator is attempting to initialize OpenCL.
Detected 1 OpenCL Platforms:
0: NVIDIA Corporation. NVIDIA CUDA. OpenCL 3.0 CUDA 11.4.153.
Supported extensions: cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_fp64 cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_icd cl_khr_gl_sharing cl_nv_compiler_options cl_nv_device_attribute_query cl_nv_pragma_unroll cl_nv_copy_opts cl_nv_create_buffer cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_device_uuid cl_khr_pci_bus_info
Selected matching OpenCL Platform: NVIDIA Corporation NVIDIA CUDA OpenCL 3.0 CUDA 11.4.153.
OpenCL evaluator choosing OpenCL platform NVIDIA Corporation.
Choosing OpenCL Device NVIDIA GeForce RTX 3090. Device Type: GPU Device is available.
I've found the same issue with Maya 2022.5 on Fedora 40. It looks as though it's an issue with Maya's 'Home Screen'. My solution was to type [ALT] + [HOME KEY] when the blank Maya window comes up, which switches to the normal Maya UI. Click [Windows] > [Settings/Preferences] > [Preferences]. Click 'Interface' in the tree to the left, at the very top uncheck 'Show Home Screen on startup' and 'Show Home icon in menu bar'.
Of course it's not really a solution if you want the Home Screen - but I confess I've found it little more than an annoyance so happy to be rid of it - and it doesn't answer the Shot Grid problem I'm afraid. As a stab in the dark I'm wondering if this is a QT bug.
|S
