Bifrost problems
Bifrost problems
Bifrost problems
Hi Guys. Been trying to make a cube an emitter for bifrost and whenever I do this I get an error message saying: // Error: file: /Applications/Autodesk/maya2016.5/plug-ins/bifrost/scripts/addBifrostLiquidAV3.mel line 51: setAttr: No object matches name: unknown2.bifrostRenderType //
Then when I select my cube (emitter) from then in attribute editor it says my object is "unknown1". I'm more than a little puzzled to be honest.
Any Maya ace's got any idea what's going on?...Please! 😉
mspeer
Hi!
Try a reset of your preferences.
Rename the folder prefs in folder 2016.5 to something like prefs_backup, or to reset everything, the folder 2016.5 to 2016.5_backup. Maya creates new folders. Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
OK, Thanks. Will give that a try.
sean.heasley
Hi @Anonymous
I'm just checking in to see if you need more help with this. Did the suggestion that @mspeer provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
