Beginner question about sets
Zeriel00
Zeriel00
Hello, I've been using Maya for a while but I've been ignoring these sets that get created automatically in my outliner, that is, until they cover my whole screen! I know they're related to selections but my questions are how are these sets created automatically? How are they different from groups? What is their purpose when we already have Layers, Groups and also Sets? and can they be set up so they're not auto created?
O_OO_O
sean.heasley
Hi @Zeriel00
Good question! We have an article on sets here but in the simplest terms, unlike groups sets do not alter the hierarchy of the scene - they're simply an arbitrary collection. They are always saved at the scene level, and cannot be part of an object, group, or hierarchy.
Unlike layers, sets can actually be used to hold vertices, faces, edges etc. For example, you can select many vertices on a polygon object and put them in a set so that you can select and model with them easily as opposed to having to switch to vertex mode and manually select the vertices each time etc.
Please let me know if this information is helpful or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Zeriel00
Thanks for the info! I only have two questions left; Why are sets being created automatically? I didn't make any of them on purpose, and can I just delete them? I've had some instances where deleting sets made my mesh disappear, is this supposed to happen?
Thanks again
sean.heasley
Hi @Zeriel00
It tends to happen with certain things being created and/or combination of changes being made. I know I've seen it happen in the past but there aren't any 100% reproduce able steps that I'm aware of.
That said, you should be able to simply delete them. To be safe, when you select a set just check your viewport to make sure no objects are selected before deleting them!
sean.heasley
Hi @Zeriel00
I'm just checking in again to see if you need more help with this. Did the information I provided on Friday help you understand this?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
