Batch unable to find a GPU device
Gen_T
Gen_T
So I'm using Redshift with Maya 2017 and everything renders fine via the render view, however, when I try to batch render I get this error and the render just quits within seconds.  I even tried this in Maya 2016, same thing.  Swapped out preferences and reinstalled, same issue.  It was rendering fine a couple days ago now not so much. Help! ><
OpenCL evaluator is unable to find a GPU device that can share VBOs with OpenGL.
damaggio
If you have two video cards try to disable one of them
damaggio
I faced a similar problem a while ago . I'll send a note later when I'm at computer
damaggio
Here, don't know if this could help you but check it.....
Gen_T
Thanks for the info! I have one card and I updated the video drivers and the problem persisted.  However, grabbing everything and tossing it into a fresh scene made the issue go away.  I thinks some screws came lose when the scene migrated from 2016 to 2017 and I've been running into enough issues to not question why this happened, I'm just glad its over ha!
