Baking Arnold catclark geo is breaking my UVs
osukas
osukas
Hello, I want to export a character that has catclark subdivision with a displacement map.
I followed this tutorial:
https://youtu.be/UUTeJHRaKRw?si=zXQMHNqPcyeGA52z&t=50
The geometry works perfectly, but the problem is that the UV breaks in the seams area, the seams are merging together.
Here is an example with a cube
UV of the Original CUBE
UVS from the baked obj with catclark
These are my settings
how i can export it and preserving my UVs
syracoj
are you using the Arnold > Bake Selected Geometry Utility?
can you zip up and send us your scene file?
lauri_barnhart
Hello @osukas,
I just wanted to check in to see if you saw @syracoj's follow up questions. Are you still needing assistance? Or did you find a solution to your question already? Please share any available screenshots or screen recordings so the community can assist you further.
Lauri | Community Manager
