Arnold Rendering Empty Image?
andymc4997
Message 1 of 10
andymc4997
Maya 2019, Win 10, Arnold
I'm trying to render a tif image with a transparent background in Arnold Render View. When I try to save the image, it opens in Photoshop as nothing but an empty canvas. The same thing happens if I try to save a PNG. However, when I save as JPEG, the image opens up just fine, but obviously with a black bacground (not what I want). Needless to say this is incredibly frustrating. What is going on?
Replies (9)
Message 2 of 10
Stephen.Blair
sounds like photoshop is premultipling the image on load
// Stephen Blair
// Arnold Renderer Support
Message 3 of 10
andymc4997
Pre-Multiplying? I've used the application for 14 years and have never heard of that. Is there a fix?
Message 4 of 10
andymc4997
Anyone have any ideas?
It's really important for me to be able to save out images with transparency for my current job project, and I'm on a deadline. I'm currently just throwing a surface shader on the object and rendering a faux alpha channel so I can clip it.
Message 5 of 10
mspeer
Hi!
Please upload a scene-file + one rendered image.
Message 6 of 10
christofstanits
I have the exact same problem.
files attached.
I can either have a png without transparency or a blank tif.
Message 7 of 10
christofstanits
its the contour filter.
Makes tifs go blank. investigating further.
Message 8 of 10
mspeer
Hi!
This is very likely not the same issue as there is a difference for PNG and TIF in your case.
Why are you using the contour filter if there is no toon shader in your scene?
The TIF file is correct, the content should be empty without a toon shader, the PNG file is wrong.
For proper alpha support I recommend to render TIF images, also use the contour filter only when rendering a "contour" for the aiToon shader.
Message 9 of 10
christofstanits
because I am going for toon shader but switched it in testing.
If I use a toon shader, tif only gives me the outline, but no shading. Although the render window shows both.
png only gives me shading without alpha.
so the only solution (toon shading plus outline) is to render separately, even if you dont need it for your project. (i dont)
render box filter for shading and alpha
render contour filter for outline.
things that are confusing:
difference between render Window and render Sequence
my tif shows a preview of the rendered pixel-shading in windows explorer, also the fileSize is not zero (theres sthg in it) but photoshop displays it blank.
Message 10 of 10
Is there any solution to rendering toon shaders with contour and getting an alpha? seems like a pretty basic ask for Arnold to have this working.
