Arnold Render selected objects?
lou4uandme2
lou4uandme2
Hi All,
I am trying to render in Arnold just 1 object I'm my scene. When I check the box that said "selected objects only" it renders just the object, however, the buckets still render the entire frame.
For example,
if I had a sphere oject in the center of frame, the buckets start from the outer edge and spiral inward towards the object.
I watch 1 minute of the buckets rendering blank areas until it gets to my object.
Is there a way to JUST render the object ONLY and not waste time scanning the blank areas?
Lou
"I Create, therefore I am"
Louvfx.com
mspeer
Hi!
With Maya 2017 on Windows it works correct (and the render spiral starts from inner).Only the Environment like Background and Atmosphere seems to be rendered anyway. I tested with a big background cube and a small sphere in front, can you do a test with such an easy scene too, to see if it's a general problem or scene-dependent?
lou4uandme2
Ok, I will start a new scene to test. Because the scene I am using now renders a clear background but it's taking just as long to render the emptiness as it is to render the object.
Thanks!
Louvfx.com
