Arnold procedural mandelbulb_proc.dll
levinheselhaus
levinheselhaus
Community Visitor
Community Visitor
I am trying to follow this tutorial: http://area.autodesk.com/learning/how-to-render-a-mandelbulb
I dont know what i am doing wrong. It looks like Arnold doesn't load the mandelbulb_proc.dll.
If i try to render the standIn inside of maya i get this error: // Error: [ass] line 80: node "mandelbulb" is not installed //
I am sure that ARNOLD_PLUGIN_PATH is set correctly.
If i try to render it with 'kick mandelbrot.ass' i get this error:  unable to load dynamic library C:\User\***\***\mandelbulb_proc.dll: The specified procedure could not be found.
Am i doing something wrong? How can i fix this?
Stephen.Blair
Hi
You don't say what version of MtoA you use.
I'm using MtoA 2.0.0.1, and here's how I kicked the ASS file:
cd C:\solidangle\mtoadeploy\2017
set ARNOLD_PLUGIN_PATH=C:\Users\blairs\Downloads\area_mandelbulb
bin\kick -dp -l shaders C:\Users\blairs\Downloads\area_mandelbulb\mandelbulb.ass -v 5
Note that you'll get some pop-up errors because kick tries to load procedurals like bifrostapi.dll, and those depend on Maya libs. You can ignore those (just click OK). We're going to fix that.
// Stephen Blair
// Arnold Renderer Support
Stephen.Blair
And to render it in Maya:
  • Use a standin to load the ASS file
  • In the Render Settings > System > Search Paths, add the location of the mandelbulb dll to the Plugin Search Path
// Stephen Blair
ian_zeigler
  • Use a standin to load the .ASS file
  • Have render settings, system, search paths pointing to .dll
Most likely I am missing a step...
any help is appreciated!
