Yea GPU is definitely the way to go and investing in the new RTX cards is a good idea. I talked to someone over at Puget Systems and they mentioned with renderers like Redshift we can expect 1 RTX 2070 to equal 2~3 GTX 1070 cards as they begin to take advantage of the new technology.
There really isn't an argument against GPU rendering, speeds are hugely faster, that's why Solid Angle is developing it.
The only other thing against GPU rendering is scaling the hardware. It's harder to scale up and network GPU's as they connect through the PCIe slots. Putting together a single system that supports more than 4 cards is pretty challenging at the moment. Render farms generally charge more for GPU rendering probably because of this.
For most freelancers working on a single system though, GPU rendering is really the most practical.
(delete)
@Anonymous wrote:
I'll have to try one of my previous projects to get a comparison in effeciency, but for now it looks promising. And as far as I understood Arnold GPU isn't even using RTX yet? But that would probably only affect scene with high amount of environment and specularity?
Arnold GPU uses Optix, so it automatically gets RTX support.
RTX cores speed up the ray tracing, which could be 30-50% of the total render time. So you could get up to 2x speedup. The rest of the render time is the actual shading.
Muchas gracias por la aclaración.
Tengo un problema arnold no reconoce mi tarjeta grafica AMD 5600xt, el computador solo quiere renderizar con CPU y me arroja el siguiente error: // Error: [gpu] unable to load NVIDIA CUDA (GPU-rendering .
Ya actualice los drivers de mi tarjeta, instale de nuevo maya y no encuentro solución.
Agradezco tu ayuda y quedo atento.
AMD cards are not compatible with Arnold. It requires cards with CUDA cores which means Nvidia cards only.
