After Effects Live Link fail
I'm trying to use the after effects live link with Maya 2018 but I can't see anything I send to after effects, the content layers are created and if I select them a kind of bounding box is mark but nothing else is showed. Help please.Captura de pantalla 2019-01-15 a la(s) 21.58.17.png
sean.heasley
Hi @Anonymous
Did you set up the connection properly?
Also, if you export normally instead of via Live Link and then import into After Effects does the same issue occur?
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Sorry I got busy with other stuff, but I'm still having the same problem. Not even exporting and importing the elements, I can't see anything.
sean.heasley
Hi @Anonymous
So now you aren't seeing anything when you go to import into After Effects?
Have you tried unloading and reloading the Live Link plug-in?
