Archive Scene not saving image files imported with AiImage
I have an issue when I archive a scene, maya only archives the files that are imported with the “2d texture file” nodes not the aiImage files. Is there a way to correct this or to correctly archive a scene?
Thank you!
patrick.schock
Autodesk Support
Autodesk Support
Hi @Anonymous,
thanks for making us aware of this. I could reproduce the behavior and logged this at development. As of now, I would recommend to manually create a zip file of the Maya project. In case that not all textures are stored into the project, you can use the File Path Editor at Windows > General Editors > File Path Editor to collect all textures.
Best regards,
Patrick
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
Thank you!
DaveMay3D
In case anyone isn't counting, it's 2024 and this is still not fixed (4 years).
